13.5 BTU non-remote or wall thermostat. Controls are on the unit face.
SOURCE: dometic ac
remove the lower assembly and tighten the bolts that hold ac down to coach or pull shroud and check to make sure unit is not frezing up due to dirt
SOURCE: Rewire 12Volt into 24Volt
You have to get you a transformer .voltage input 120 and out put 24 volts.But will have to wire it through a relay or contacter with the coil volts 24.
SOURCE: The fan runs, but doesn't get cold.
You'll have to get someone familiar with system to check relays, capacitors, as well as power to compressor. Can be dangerous, so please if not 100% sure what your doing, ask someone who does know.
SOURCE: the compressor will not shut off when the temp
This is very much relay problem. The olden days relay get stuck due to residual magnetism. Or spring would have snapped. Or contacts would have bonded permanently. Check these or replace the relay totally.
