Just installed game, however when i start a new game all chests are empty so i cannot complete quests, and creatures inside building locations are not there. need patch for this
1998 Quest is fuel injected. New fuel filter is good but you may need to change it again after checking for plugged injectors. This is not a fun repair to do on side of road. It is possible that fuel lines may be clogged depending on how nasty the fuel in the tank was, especially near empty. The fuel strainer, in gas tank, may be corked up as well.
It's not magic. There is a route the electricity take on it's way to the starter. Battery to ing sw via fuse. Ing sw to starter solenoid. Solenoid engages teeth into flywheel and connects large wiring on starter motor. Trace in that order and you will locate the problem (or tap the starter while someone holds the key in start position).
I just installed an after market radio in my 94 Quest. The easiest way is to buy a Nissan Quest Radio Wiring Harness for Premium Sound.
It will have the complete wire hookups.
You can also hook up the blue wire from the new radio to thefactory (I think Blue or Blue/White) wire on the harness.
That will turn the factory amp on.Hope this helps ,good luck
