Nikon Monarch ATB 7345 Binocular Logo
Anonymous Posted on Feb 27, 2012
How to tighten binocular hinge
I dropped the binoculars on a tile floor while they were in their carry-case. When I checked them, I noticed that the hinge on one side had become much looser than the other one. I would like to make the loose hinge as stiff to move as it was originally.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 13, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6986
Points
Simple solution: Pry or unscrew the cap covering the end of hinge shaft on the rear of the binocs (between the eyepieces). Use a screwdriver that fits snugly in the slot on the end of the shaft & tighten to desired tension. Place a dab of Goop-type cement on the inside of the cap if it was pried off & press it firmly back on the shaft . Helpful hint: Slide a small knife blade (an old dull one you don't use for cutting) under the cap and gently work your way around to pry it off. Note the position of the index numbers before you remove it so you can replace it in the same position.
3 Related Answers
Anonymous
  • 112 Answers
  • Posted on Dec 22, 2008
SOURCE: Binoculars Stiff to focus
if they continue to get stiff then eventually the 3 set screws that hold the focus wheel loosen, and you will have no focus capability, its rare with zeiss but sounds like they should be regreased. the problem is to regrease you have to take completely apart as it is internal focus.if i can help any further contact me@ [email protected]
Anonymous
  • 43 Answers
  • Posted on Mar 02, 2010
SOURCE: nikon compact binocular 25 years old. The hinge
Does this pair have two parallel tubes with a bridge in between?
If it does, then removing the caps at the eyepiece end of each hinge will reveal a grub screw. Tightening these will add tension to the hinge and give you the proper feel once more.
Anonymous
  • 112 Answers
  • Posted on Feb 20, 2009
SOURCE: hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
Is it possible to have Eagle Optics binoculars repaired/refurbished?
Probably, but this once relatively inexpensive process became expensive under the onslaught of masses of very good inexpensive imported binoculars and other optics resulted in many repairers dropping out of the market - 50 years ago camera shops abounded in every town and almost every **** store/pharmacy/chemist shop would handle repairs or even carry them out themselves; mostly these have disappeared.
I think the binoculars would need to be something quite special to make refurbishment an economic option. The usual reason why repair is needed is either dropping in water, dropping on a hard surface and disturbing the prisms or any zoom adjustment failing...
Below is a link to the search results...
https://www.google.com/search?q=Eagle+Optics+binoculars+repaired%2Frefurbished%3F&rlz=1C1CAFB_enGB673GB676&oq=Eagle+Optics+binoculars+repaired%2Frefurbished%3F&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
1helpful
2answers
Tighten minolta 10X40 j-B35
Cloudynights person says it was very difficult to get the cap off the hinge so that he could tighten it. He had to hone small screwdrivers until he could pop off that hinge (it is so well sealed for the WR rating, I suppose). Then he could get to the bolt that tightened the hinge so the binos stopped flopping about. I still don't know how he got that cap off, though.
Nikon compact binocular 25 years old. The hinge
Double vision with the optics. Dropped and now the binocular has double vision.
The yoke which connects the eyepieces and keeps them aligned as the focus changes is damaged. If you can easily move one eyepiece back and forth with respect to the other then the yoke has broken, if not then it's bent, probably cracked and waiting to break.This is probably the most common fault on most binoculars, and it's usually uneconomic to repair.
If bent, the yoke *might* be able to be straightened, but it will be weakened and the alignment afterwards will rarely be spot-on. If broken, then the yoke must be replaced professionally but the repair often costs more than replacing the binoculars with new. The break cannot be simply glued: the contact area is too small to carry the loads it has to carry, and you also usually find that the yoke bent before breaking anyway so you then have all the same problems as you do with a bent yoke.
The fragile nature of the yoke is why binoculars must always be inserted into their case with the objective lenses facing down; this avoids shock loads on the delicate yoke assembly.
If you have a telescope and binocular repair specialist located conveniently to you then it may worth getting an estimate for repairs, but there are few these days with the skills to do so. Minolta no longer exist, so spare parts will be almost as scarce as rocking horse droppings. But if you're in the UK, then visit or phone Kay Optical for advice.
I hope that you've found my posting to be of use and in return ask only that you take a moment to rate my answer.
1helpful
I have Minolta Pocket 8x24/8.7, 40 year old binoculars. One side is "limp" and doesn't stay in position for viewing. Fix??
Most compact binoculars have a central bridge. The objective (big lens) end of the binocular hinge usually has a ball bearing in it. The other end may either have a blanking cap or a hub where the neck strap attaches. Removing this cap or hub will reveal a grub screw which tightens another ball bearing against the bridge. Take the appropriate part off the limp side and look for the grub screw. Tightening it will decrease the "limpness". Be careful, as these are sometimes set in place with a locktite of some kind. Best to release pressure first before tightening.
2answers
I have double vision with binoculars. When I look at jupiter for example, I see 2 as if the optics are not aligned.
Your question is listed under "Zhumell Oberwerk 45 25x100 Astronomy binoculars". If these are what you have then they're an extremely high end expensive specialist item and will need professional realignment. I'm assuming that if you do own a pair of these then you're knowledgeable enough to have done all you can to adjust them correctly.
I suspect that you have a regular pair of 10x50 or similar binoculars, with a centre focus wheel and hinges. If this is the case then try to wiggle one of the eyepieces back and forth: if you can easily move it and the other eyepiece remains steady then you have a broken hinge. This is a very common fault especially if your binos have been dropped or if they've been stored in their case upside down (i.e.standing on the eyepieces).
A broken hinge is normally a write-off as there is rarely sufficient area to us epoxy glue on and the metal used is not usually suited to being brazed. Even when the hinge can be repaired it's normally permanently misaligned.
Either resign yourself to using one half of your binoculars or buy a new pair. In the UK LIDL regularly sell a pair of Meade 10x50 binos of excellent quality for just over £10 and that's only a little more than a bottle of epoxy resin glue costs. You may be interested to know that one of the world's most successful supernova spotters does so in his back garden in the UK using just half a pair of old 7x50 binos.
Binoculars are too loose to hold eye to eye spacing/
under the bottom hinge cover there should be a hinge nut you can tighten, if i can help further call 5088331232...larry
4helpful
Hinge on binoculars is too loose
I cant find friction adjustment on Minolta 10 x 40 binoculars
Hi Ray:
I have Minolta binoculars with the same issue, I believe that I also have the same Minolta model: 10x40mm, roof mounted prisms, 5.6 degrees, waterproof (WR series) and model number j-b35.
Have you found any solution for the loose center hinge?
[email protected]
Feb 01, 2009 • Optics
Top Nikon Optics Experts
john h
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Nikon Optic Expert? Answer questions, earn points and help others
