I have a ge universal remote. It works for the most part but I cna't get the TV to program to any channel under 6. I need to get to caneel 3 or 4 to play the DVD or VCR. What do I do?
You can't post conmments that contain an email address.
Just do a factory reset to this set. To do this, you have to enter its service mode option. Just understand, this is most likely a semi-skilled work. If you're not confident about it, contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
Follow the same steps to enter a code but instead of entering code press the channel up button repeatedly until it turns the tv channel and when it changes (dont press up again or else you will have to do it over again). When you get the remote to change channel STOP! and press the enter/ok, or similar button to lock the code in and you should be set. Good luck. If you follow the steps and it doesnt work the first couple of times dont be discouraged, Trust me all universal remotes allow you to set up you universal remote this way i guess they already know people lose the universal remotes instruction manual with all the codes in it! Hope this helps GOOD LUCK too you. Hope this works out for you!!
Hello, you set your TV for channel 3 or 4, if your combo has an out to TV RF connector(threaded connector) or you set the TV for video 1or video 2 if it has the RCA video/audio outs in the rear. If the TV has no auxiliary jacks you will need an RF converter, usually common in any electronics store(radio shack or similar).
You will need to re-scan the channels, i don 't know where it is on the menu of this set. If you are on cable, you need to make sure your tv is set to cable tuning, or you cannot get channels past channel 13. Same is true for antenna if you are on antenna make sure you are set for this.
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Sounds like you need a set-top box from the cable company. You hook that up to your TV, tune the TV to Channel 3 or 4, and use the set-top box to tune in all the channels.
Apparently your TV is set to the "standard TV"
position. Before you auto program your set, set it to the cable mode and then do the autoprogramming.
In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13
plus your cable channels.
Stargazer
