SOURCE: Maytag Neptune gas dryer model nbr MDG 4000 BWW.
A very common problem in a non-heating gas dryer is what is called the gas coils, especially if it will light briefly and then go out and not relight. You should also check the igniter and make sure there are not cracks or burned places, also thermal fuse and thermostat could cause a no-heat.
SOURCE: How do I get the dryer apart so I can replace the
My Maytag dryer has two Philips headed screws low on the front surface of the dryer below the door. It is easy to get the front off. There is also a small panel with four screws on the lower left side that can come off so you can get at the motor and belt assembly.
