Relatively new but passed warrenty. rotates, just won't hammer
SAME ISSUE *****SOLVED*****
You were on the right track but needed to go farther with top description without disassembly!!
I have a barely used Hammer drill also that will rotate and run motor but does not hammer in any position.
Grease is the issue.....
Heat and sitting causes the grease to weep out & even a small amount of dust binds up the hammer drill.
******SOLUTION*****
GREASE, GREASE & MORE GREASE....
REMOVE BIT....SQUIRT IN ALOT OF THE BOSCH GREASE HOLD LOCKING CHUCK OPEN. INSERT A SPLINED BIT INTO THE HOLE AND PLUNGE GREASE IN SLOWLY SEVERAL TIMES. REMOVE BIT & REFILL GREASE & REPEAT.....VOILA.....HAMMER WORKING AGAIN....
BE SURE TO USE LOTS OF GREASE & DUST COVERS ON Bosch HD WHEN WORKING. WE ALL ERROR AND FAIL TO MAINTAIN FROM TIME TO TIME!
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
SOURCE: i have a bosch rotary hammer 11245evs and it was
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
SOURCE: the bosch 11227e rotary hammer will not energize when
It sounds like the cord is ok as you have power to the switch. It also sounds like the switch is OK. These units have a governor on them as well. I suspect the governor because you indicated that the hammer will not come up to full speed. Beyond the governor, the only other thing to look at is the motor. You did say that you didn't notice any sparking so the motor sounds like it is OK.
In my opinion from everything you said, its the governor.
SOURCE: rotary hammer won't rotate, hammers very good
If tool hammers brushes still good. Motor runs hammer action.
Take hammer/ drill switch lever off by removing small plastic plug in center with small screw driver.remove indicator handle off by removing #8 torx screw and lightly pry off. There is a pin and spring that lock tool into hammer or drill.Check for broken spring or binding spring and pin.If binding , clean and grease.
SOURCE: Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
