Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtmlAbove shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtmlClick on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Do you still have the manual of your motherboard?
