I have a mitsubishi ws65513 with the same dreaded green blinking light. The t.v. will not power on. I've tried the troubleshooting in the book with no luck. I hear this could run me approx. $1000.00. Is this something I can fix myself?I have a mitsubishi ws65513 with the same dreaded green blinking light. The t.v. will not power on. I've tried the troubleshooting in the book with no luck. I hear this could run me approx. $1000.00. Is this something I can fix myself?
I have the same issue with the green blinking light on a 65" hdtv ws-65511. Is there anything that I can do myself. I tried the reset button and unplugged the tv, but it still blinks green and steady. Please help. I have the same issue with the green blinking light on a 65" hdtv ws-65511. Is there anything that I can do myself. I tried the reset button and unplugged the tv, but it still blinks green and steady. Please help.
AnonymousMar 03, 2009
My 65" Mitsubishi Diamond set is approx. 6/7 years old, and never had one problem with it until this past weekend. I have the same blinking green light problem, and it is driving me crazy! If this is a costly repair and considering the age of the set, I may just start shopping around for another set. My 65" Mitsubishi Diamond set is approx. 6/7 years old, and never had one problem with it until this past weekend.
You can't post conmments that contain an email address.
I hve the Mitsubishi HDTV TV 1080 series integrated. The TV will not power ON and the green light just blinks. I have unplug TV for a while a few time, but still same blinking green light when I plug back in.
I am not able to use remote control.The TV will not power ON and the green light blinks for a minute when I pressed the Reset button. Recommend a solution for this problem.
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Power supply board is dead,if green light on keep blinkings,notthing come on.Power green light is solid,nothing come on.Than ur Tuner signal board is dead.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did. Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Green light blinks and TV will not come on even after I hit reset button.
same blinking green light...seems to have gotten worse over time
