SOURCE: I have the black and decker hammer drill model
look at the back of the brush holder for a tab that the forward/reverse lever locks into, it might be broken not allowing it to shift.
SOURCE: Hilti TE-5 does not drill
Check the motor if the motor has power and then the gears are not working. If the motor doesnt have any power then you need to check for power. To get at the gears you are going to need to remove the chuck
SOURCE: drill doen't hammer in drill hammer position
If the unit no longer hammers it may be time for a service pack. (overhaul). You can get overhaul kits at any Bosch Authorized Service Center.
SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
SOURCE: Describe your Dewalt & 14.4V Xrp
Hello. I can help you. Your motor is producing the smoke. Before more damage is done I recommend taking it or sending it to a Dewalt sercive center.
