Question about Amana Refrigerators
FREEZER DEFROST I HAVE A AMANA SIDE BY SIDE. I HAD A REPAIR MAN COME TO THE HOUSE AND HE FORCED THE FREEZER TO DEFROST.OT REMEMBER HOW HE DID THIS. SOMETHING ABOUT THE FREEZER TEMP CONTROL AND TURNING IT BACK AND FORTH 5 TIMES. IS THIS CORRECT ?? I CHECKED THE COILS IN THE BOTTOM OF THE FREEZER COMPARTMENT AND THEY HAVE A LIGHT FROST. CAN YOU HELP ??
6ya staff
SOURCE:
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
Anonymous
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
robert samples
  • 1314 Answers
SOURCE: amana abb222zde bottom freezer not defrosting
email me at b4829@yahoo.com ref amana
Posted on Jan 29, 2009
Anonymous
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Is there a way to disable the frost-free feature on amana freezer
Unplug your refrigerator and open the rear panel in the back of freezer. Disconnect one whire on one end of the defrost heater. Tape the wire up and you'll be good to go no defrost. Sea Breeze
Posted on Aug 19, 2009
How to test Damper control in Amana DRS2660bw MFG No PDRS2660bwo S/N 10650033CT
the control damper does not control the freezer temperature call a repair man as it possibly needs freon added
Jan 22, 2017 | Amana Refrigerators
Amana ars2464bs quit working overnight. Freezer may have been left ajar, all night. The motor is hot and a clicking sound can be heard every couple of minutes. Frige and freezer room temp.
Unplug and manual defrost This happens when warm moist air is drawn into refrigerator. It freezes as frost and confuses the motherboard or defrost timer and put a heavy strain on compressor.. You also have a defrost timer inside the fresh food compartment. It is possible you can run forward to force defrost=> 67001036 Defrost Timer turn timer with small flathead screwdriver slowly clockwise.Click Here=> ARS2464B Amana Refrigerator Control Parts List Part 711 in top left photo can be found in the control panel inside the fresh food compartment. Try that and let me know if this helped, Thanks, Sea Breeze
Click Logo below=>
Mar 21, 2011 | Amana ARS2464B Side by Side Refrigerator
I have a 8 year old Refrigerator Freezer Model number ARB9059CS. It has been making a buzzing sound. I had a repair man who replaced the relay. We were away for a few days and came home to more buzzing...
personally i would replace any item in the home that cost more than $500 to repair,you can save that much in lower running cost for a more upto date version.but ....its your money.
Oct 11, 2010 | Amana Refrigerators
DOESNT DEFROST AND THE FRIDGE SIDE NOT COLD
YOU CAN MANUALLY DEFROST THIS AND GET IT GOING UNTIL YOU GET IT REPAIRED. UNPLUG REFRIGERATOR AND LEAVE FREEZER DOOR OPEN FOR 12 HOURS OR MORE. OR UNPLUG REFRIGERATOR, TAKE THE LOWER PANEL OFF INSIDE FREEZER AND DEFROST WITH A HAIR DRYER. THIS SHOULD TAKE ABOUT 45 MINUTES. THE MOST COMMON REPAIR IS THE DEFROST THERMOSTAT. YOU PROBABLY HAVE A BAD ADAPTIVE DEFROST BOARD.
Apr 26, 2010 | Amana ARSE665BS Side by Side Refrigerator
Amana Side by Side - Defrost using control board
http://shop.amana.com/product_literature/search.jsp?siteCd=AMA
try this web site and fill in your model number. See if this will get you your manual on your unit.
Hope this gets it for you.
Mar 18, 2010 | Freezers
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
My Amana SCD23VW quit producing ice cubes. It was one big melted mess. Also freezer will not get cold enough to freeze now. Please help.
your frig is not defrosting you should see frost on the back panel remove items from frzr and remove the back panel off and thaw the evap coil if you can not get repair person to your house it will oper normal until it frost up again, generally it will be one of 3 thing dfrst heater, dfrst thermostat, dfrst timer
Sep 03, 2009 | Amana SXD524VW Side by Side Refrigerator
Our freezer is not cold, food is defrosting, ice is melting. Refrigerator is working, freezer is not. We hear compressor running continuously. This is a side by side Amana model with water & ice maker...
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
