Cars & Trucks Logo
John Carlton Posted on Feb 14, 2012
How can I tell if electrical problem is alternator or battery on 1998 buick century?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Feb 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
805
Points
12
Easiest way - You can connect a good battery to your car (borrow a friend's) - if it cranks over and stays lit - it's the battery. When it is running on the friend's battery - use an Amp meter to tell if the alternator is generating any amps. Just stick the probes up to the wires on the alternator and see if the meter moves. If it doesn't move you need a new alternator and regulator.
Amp meters are cheap and you can get one at Radio Shack.
5 Related Answers
Anonymous
  • Posted on Sep 23, 2008
SOURCE: Where is the fuel filter located for Buick Century 2001
The fuel filter is located underneath the car in front of the gas tank.
You have release the fuel pressure. Remove the fuel filler cap, locate the fuel test port on the fuel rail on the passenger side on the end of the right real fuel rail for a 3.1L engine.
3.8L engine yhr test port is located at the pressure regulator under the trim cover.
Anonymous
  • 405 Answers
  • Posted on Dec 18, 2008
SOURCE: Heater/AC Fan does not work in our 1998 Buick Century
Fan will be under dash on passengers side , Removing glove box might be needed, Gm also uses a blower resister ro control fan speeds. First check your fuse and then check and make sure your getting 12 volts to the terminal at the blower, You could have a blown fuse, a bad switch, or a bad resister , if your getting voltage to blower motor then most likely it will be the motor. These are not to difficult to change. I hope this helps, please be aware I can only guess at what the problem is from my past experience.
Terry Engel
  • 176 Answers
  • Posted on Jan 03, 2009
SOURCE: 91 Buick Century 2.5 L brake light on & battery light on
For the Brake light to stay on and the fluid is up...sounds like your sensor is playing dead......
For the battery to die after only (4) hours..you have a very big drain on the battery itself.....without the vehicle right here to look at would be very hard to even guess...electrical problems are a hands on chore...
I'd take it to your garage/mechainc
Anonymous
  • Posted on Mar 07, 2009
SOURCE: STEREO WIRE CODES DIAGRAM FO A 1998 BUICK CENTURY
need codes to hook up radio to 1999 buick century
Anonymous
  • 1118 Answers
  • Posted on Apr 14, 2009
SOURCE: the driver's side power window is stuck half way up on 1998 buick century limited. What is the problem?
It could be the fuse, does it go down? If not chk. fuse, if fuse ok, see if you can help it down by pushing down on window wile working switch, and also same wile trying to go up, if it don't work or if its slow chanses are the motor is tired and needs replaced or its lost power like bad switch or broken wire. there is also a chanse it came off the track in witch case the door panel will have to be removed.
Fuse for license plate light in a 2000 buick
Fuse Box Diagram Buick Century (1997-2005)
https://fuse-box.info > buick > buick-century-1997-200...
Fuse box diagram (location and assignment of electrical fuses and relays) for Buick Century (1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005).
Donde esta el fucible de un 1999 Buick Century
English ONLY on Fixya!
where is the fuse for a buick century 99
Doesn't turn on the whole board
Buick Century (1997-2005) fuses and relays
Starter
underneath the motor on battery side. positive cable runs from battery to starter
1998 buick century my heater and ac fan only work on high i'm told it's the blower relays where are they located
they are not relays its a blower motor resistor a one piece unit usually held in by two bolts and an electrical connector either under the passenger side dash or behind glove box
1991 buick century battery light on
Charge your battery and have it tested. Most part stores will do this for you at no cost. I'm leaning towards an alternator issue but it is possible that it could be both the battery and the alternator. Even if it's just the alternator the battery should be fully charged as a discharged battery can damage the alternator.
I need to know where the alternator is located on a 1998 Buick Century
it on the passenger side where the serpent belt is at hope it helps
2answers
What would cause the battery to go dead every 3 or 4 days?
A short in the wiring or depending on the amount of driving you do a bad alternator.
Don't have any electrical power bought a new battery the alternator seems to be ok but there is no lights no anything we check the fuses in the dashboard nothing seems to be blown what can the problem be?
The battery post connections are critical, and need to be clean, and snug...have you tried to jump start...and does the battery connection spark when connected? Sounds like a bad or dirty post or fitting...hope this helps...:)
1998 buick century-electrial all work but when turn key like dead
Sometimes there will be just enough corrosion on the battery terminals to allow for low draw items such as the radio but not enough contact for the most heavy draw item, the starter. Start by cleaning the terminals. Also jumping of another car to the battery cable ends will tell you if the terminals connections are compromised.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
