Question about Siemens Washing Machines
Siemens E14-16 Washing machine is not taking the softener when rinsing and posibly not rinsing completely. the dispenser drawer is clean and flows correctly when filled with water. I have checked the filter - all clear, any suggestions?
Same problem with same Siemens E14-16
Cleaned soap drawer inside out (no more black gunge) but still full of conditioner after full cycle and rinse despite 2 internal valves completely cleared and connected
What could be wrong ?
Posted on Mar 04, 2013
5 Suggested Answers
6ya staff
SOURCE:
dazmaraz
Darren Moxam
  • 67 Answers
SOURCE: WFLI2440 FRONT LOAD FABRIC SOFTENER NOT DISPENSING
your soap drawer is most likely to be blocked , the only true way of clearing the blockage is to take the soap dispenser completely out . you will see that all the jets will be blocked ,you can do this before taking it all apart by taking the drawer out band looking up, if it looks clean ie; no black gunge then it may be a water valve problem, as the cold fill side has 2 internal valves both have come on together to clear the conditioner compartment.
Posted on Feb 15, 2008
Anonymous
SOURCE: fabric softener dispensing before wash begins
I am having the same problem with the soap and fabric softner dispensing into the washer together... before I even shut the door. Shouldn't the softner dipense in the rinse cycle?
Posted on Nov 13, 2008
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: Fabric softener doesn't leave the dispenser
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Oct 23, 2009
How to check a miele novotronic anti syphon unit
During rinse, water usually flows through the softener dispenser. The cup fills up and a small siphon tube triggers a siphon action
which pulls the softener and water into the washer. This siphon tube is probably blocked with crud. See if you can pull a small cap like part out of the softener dispenser area. Clean both the inside of the cap and the hole under it. This will allow the water to flow into washer instead of flooding.
Jul 06, 2016 | Miele Novotronic Premier 500 Front Load...
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Oct 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Conditioner not being used from central drawer during cycle. Why and how can I rectify this?
There can be 2 reasons. The centre section dispenses the fabric softener in the last rinse. It works on a syphon effect.
If it is not assembled correctly the water flows over the side to avoid a flood and leaves the middle section full at the end. Make sure the inner pipe is inside the outer pipe and that both are completely clear of softener residue.
The second reason is the water inlet can become blocked therefore not creating sufficient flow to create a syphon effect. It gets blocked with black gunk and needs to be cleaned with pipe cleaners or a long cable tie. There are 4 rectangular holes above the centre section, near the front. They can be seen easily if you take the drawer out.
Hope this helps
Nick
Jul 27, 2009 | Bosch Washing Machines
SIEMENS XLM 1600 (WXLM166AGB) MACHINE WILL NOT TAKE IN SOFTENER FROM DETERGENT TRAY
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Aug 28, 2008 | Washing Machines
I have the duet ht and when I fill the soap and fabric softener dispenser at the beginning of the load they both run out. Shouldn't the fabric softener be released with the rinse cycle?
pull drawer completely out by pressing release tab on left rear of drawer remove all the cups and clean thoroughly with damp rag wipe upper portion on opening before reinstalling drawer
Aug 07, 2008 | Whirlpool Washing Machines
Rinse cycle
di you try to remove the drawer completely and check for a blockage under he dispenser itself.(sometimes te fabric softener can get kinda gunky.. if you extend the dispenser you see a little black tab in top left corner, push it down and dispenser will release, just in case you didnt know that
Mar 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Feb 15, 2008 | Bosch WFLI 2440 Front Load Washer
Washing Machines Logo
983 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Mike
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
