SOURCE: Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
SOURCE: WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
SOURCE: Kenmore fridge icemaker doesn't work after move
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the
water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
SOURCE: Leaking water on floor
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
