Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
A
Anonymous Posted on Feb 09, 2012
Whirlpool Refridgerator Model ET18GKXGWO 1 Water collects inside Main Compartment what can I do?
JR Stewart
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2017
JR Stewart
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
351
Points
Remove bottom and rear panel icemaker if so equipped there is a drain hole on the right-hand side next to the Styrofoam vents for the airflow that was blocked with ice
Whirlpool Refridgerator Model ET18GKXGWO 1 Water c - 10_8_2017_10_43_29_pm.jpeg
5 Related Answers
gabbyrielle
  • Posted on Jun 14, 2008
SOURCE: whirlpool gold
Your drain was clogged. look for the drain funnel then remove the dirt.
A
Anonymous
  • Posted on Sep 22, 2008
SOURCE: Whirlpool Gold Botom Mounted Refrigerator is not functioning in the main compartment
Frost accumulation in duct that leads to the freshfood section.
Anonymous
  • 121 Answers
  • Posted on Apr 29, 2009
SOURCE: Water building up in the main compartment
this is a plugged drain there may be a small cup up in the back of the fridge you can take out or you have to remove the freezer plate to access the drain
Anonymous
  • Posted on Jun 09, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Anonymous
  • 999 Answers
  • Posted on Aug 10, 2009
SOURCE: Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
1helpful
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Whirlpool ET1MHKXMQ01 refrigerator. Water is
It will usually br at the back of the fridge compartment, Try cleaning it with pipe cleaners, The smokers type of pipe cleaner.
1helpful
Water is dripping inside refridgerator coming from inside back center. Why? Sometimes it drips, sometimes it runs and sometimes it's fine.
Is water connected to this unit for the ice maker? If not than this would be the water that comes off the refrigeration coils as the unit defrosts. The water should be collected by a shallow plastic collector, routed to a drain tube, and empties to a pan under the frig where the water will evaporate quickly. Check drain collector for damage and drain hose for blockage.
Water collecting in fridge well
your drain line is clogged. Either drefrost the entire unit or use a hair dryer to defrost the drain line in the back of the unit's refrigerator section. Some units have a drain line in the back that is black and needs to be cleared,
Water collection in fridge
.you need to check the drain to make sure it is not clogged or blocked that would stop the water defrosted from you evaporator coil from draining into the drain pan.rare occasions the unit will stay in a defrost mode while trying to cool causing alot more water to be draining.good luck with your fridge.let me know how things go for you.
2answers
The refrigerator is collecting water under the veggie drawers. The model is ET18UMXGN0 2.
The fridgerator needs to be defrosted, take everything out of the freezer and refridgerator and unplug it for about 8 hours to allow all the ice to turn into water and then clean out all the water and clean the fridge and make sure it is all dry, now turn it back on and it should be good to go.
13helpful
2answers
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Is there a water resivior/catch under the TFR22PR refridgerator?
towards the bottom inside the fridge, you will find a gulley with a drain in the middle. this drain is blocked. push something flexible down the drain till water flows away freely
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
