The sliding doors on my van work for about 3 times then the light on the instrument cluster comes on and the doors stop working...I disconnect the battery wait 10 seconds connect it back and the doors work again for a few more times then the light comes on again and the problems repeats itself? Any ideas?
SOURCE: Rattling noise from rear passenger side ( 2005 Honda Odyssey Van)
It could possibly be a shock or strut bracket.
SOURCE: Honda Odyssey 2005 sliding doors won't open, beep 3 times
If you click once your remote control ,will open just driver side doors.To unlock all of them have to press twice , and then sliders.
SOURCE: 2005 Honda Odyssey EX power sliding door latching issue
I had the exact same issue with my 2005 Odyssey EX. Sliding door closes completely then "relaxes" after a few second and the door open indicator light goes on. You cannot lock the van in that situation. The Honday dealership told me today that the issue is with the sliding door latch mechanism. Aprox. $550 job.
SOURCE: 2004 Honda Odyssey -Both power sliding doors suddenly don't work.
have the relay checked out for these doors
SOURCE: how do i replace instrument panel lights (heat and
The center dashboard panel, which holds the climate control system, etc., must be gently pried up. Start at the bottom and work your way around. Once this is loose, disconnect the electrical connectors and the panel can be removed completely. The light bulbs are marked Gray and Black and are freed by a turning slightly. I think the only place you can get the bulbs is a Honda dealer.
