Question about Samsung SF-560 Plain Paper Laser Fax
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
  • Anonymous Mar 21, 2014
    Any Idea how I can delete the journal because Iwant to delete all tranmissions recieved but it wont delete the journal it keeps flashing up Memory Recieved
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Posted on Sep 23, 2007
    New Friend:
I have an epson office bx625fwd. Received fax not printing. caller no. displayed also displayed received snd completed but no fax printing. please help.
em: giles.surmun@btinternet.com
Posted on Feb 15, 2012
I have a question about my Brother (fax machine),model MFC-240C. Im receiving a fax and theres some paper jam show in the screen then i had fixed but i couldnt get the rest of the fax. It says a i have a 35 copy on the screen. It might be in my memory still but is there any way that i can print it out?
Posted on Feb 14, 2008
Turn ECM off and this should fix the problem
Posted on Jan 30, 2008
6ya staff
SOURCE:
Failing to receive a fax it says received in memory but not printing even when I want to print. Could you please help
Dear Barati
The printer may have some error. pl. check on the display of the printer. After clearing the error the received fax will printed.
Thanks.
Mar 16, 2015 | Samsung CLX-3305FW Color Laser...
I can send fax but not recieve fax
Check your Ink cartridge if it is fully empty means it will not print received faxes so it will save in memory
Feb 04, 2013 | HP Officejet 4215v All-in-One Printer
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
We would like to print a journal of received faxes for the last month?
it only keeps the last 60 transactions in memory!So if u recieved and sent more than 60 a day it wont be able to print the last month's faxes!
Jan 05, 2010 | Canon L120 Fax Laser Printer
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Receive fax on the fax system as well as your PC
If you change the number of rings on the fax machine to more than on your PC, your PC should receive the fax first and accomplish your goal.
Dec 19, 2007 | HP LaserJet 3500n Printer
Receiving Fax on PC
no the fax machine is designed to print any recieved faxes as it recieves them.
it will not save faxes to computer instead of printing them out
Nov 25, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung SF-560 Plain Paper Laser Fax Logo
1,440 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
