My 4 month old laptop is now completely without disk space on the C: drive and I have downloaded, installed and saved at most a total of 5GB of files etc., I moved some folders to the D: drive but it didnt help.. I lost space by the second until it was utterly gone. NEED to reset the entire computer to factory status since I have no files to lose on it anyway!! I just dont know how and I am not very computer literate these days!! Help?
SOURCE: Samsung yepp/ YP-T6 reformated now can't put tunes back on.
Use the Samsung Firmware Updater to fix it. Mine did what all of you are speaking about. I was ready to toss it then I tried the firmware updater on the CD and it fixed it. You must copy all the files from the \setup\Programs\ and \setup\Binary\ folders on the Samsung CD to a folder on your hard drive. Then connect the player via USB and run stupdaterapp.exe. It will search for the device and pop up a menu. Check the Format Data Are box and click start. It takes a few minutes and wipes the device clean but it fixed mine.
SOURCE: install games on samsung D900, says unsupported file format
Well it certainly is easy but people have made it difficult you don`t need to do much ok
I`ll provide you with easiest steps ever
1.download some games with both formats and put them in the same folder ok both extensions of the files would be like
EXAMPLE:- Driv3r.jad and Driv3r.jar
2.Also download Softick PPP 2.21*** just write it on google you`ll get it
3.Get A Bluetooth Device or Blutooth Dongle and connect it to PC, remember the blutooth icon below the left side of the task bar goes blue....
3.Now Activate Bluetooth on your Samsung SGH-D900 and go back to the main screen and enter the code #*5737425# and you`ll get a new menu open,the headline of that menu would be JAVA SERIAL
and Below that would be 1.PPP UP 2.Serial Download and 3.RUN TCK
4.Now after the softick is installed open it and an icon will appear on the screen on the taskbar below
right-click it and activate it be patient while it would be activating you`ll get a on-screen msg on your mobile that`ll be SERIAL CONNECT WITH DEVICE and you should accept it and then look back on the same menu of JAVA SERIAL then click PPP UP and it`ll take you to two more options just click BLUETOOTH and you`ll be headed back to JAVA SERIAL MENU.
5.Now You Need To Download The SAMSUNG JAVA UPLOADER similarly write it on google and you`ll find it easily now open it and A window will appear go for ADD
a window will open remember it only adds jad files don`t forget to get the jar file for the same prog.
and then add the jad file on the same JAVA MENU after all steps click serial download
GAMES WOULD BE INSTALLED AND ENJOY
Remember just after a game is installed repeat the same step but you would not go for PPP UP just go for serial download and its all done
SOURCE: Can't scan documents
For the system to work
completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of
awkward, download Picasa 3 and if you have installed the scan driver
correctly, you can use Picasa to import the scans by controlling the
printer. It also allws for some other tweaks that are not so easy to
get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
SOURCE: computer cannot restart and i fear i will lose
Hi there
The delete restoration data indicated the system has gone into hibernate mode. If you had any unsaved Word documents open on the screen before it went into hibernate mode, only the unsaved changes will be lost. The actual documents (if previously saved) will remain saved.
You can safely accept the delete restoration message, and the system will boot as normal and let you login. As long as your current work was saved, it will stay saved.
I hope this helps. Kindly rate my solution if I have been helpful.
Thank you.
Testimonial: "great. thanks."
1. Reinstall laptop with Windows installation CD
Maybe it is the first method we can think of. But this method is a little dangerous, because if you reset laptop with Windows installation CD, all the data on your laptop would be lost. You had better use it without any other methods but it.
2. Unlock Dell Laptop with Password Reset Disk
Password reset disk is an asset. Only you have created one before laptop locked, you can use it to reset forgotten laptop password.
3. Restore Dell Laptop to Factory Settings
Certainly it can help you, but it would take your laptop to the original settings. You would lose all the other data produced from the first time you use laptop.
4. Unlock Dell laptop with third-party software
Free third-party software is available, while I recommend you the newest Windows password recovery tool - Windows Password Genius. Why? For example, the free software Ophcrack only can be reset Windows password not longer than 12 characters. And just as we know, new things will be more advanced than the old things generally. So the newest Windows password recovery software makes progress in function and user experience. Just in order to provide user-friendly interface and more perfect function, it has been modified many times. Now, let's see how it reset Windows forgotten password.
Step 1: Windows Password Genius download and installation.
(1) Prepare an accessible computer and blank USB drive.
(2) Download Windows Password Genius on the computer and install it following wizard.
Step 2: Password Reset Disk Creation.
(1) Run the software and plug USB drive into available computer.
(2) Make sure you choose the right USB device from the drop-down box.
(3) Click "Begin burning" and wait for reset disk burning completely and successfully.
Step 3: Unlock laptop with password reset disk.
(1) Plug USB device into locked HP laptop
(2) Press F2 to enter BIOS when power on Dell laptop, and then press ALT + PageDown to enter next page, you will see the boot priority option.
(3) Modify the USB device as the first boot option, save the changes and exit.
(4) Dell boot from USB drive with password reset disk, and laptop starts with WinPE systems. Windows password recovery program runs automatically.
(5) Select the account to Reset Password and Reboot Dell laptop.
Source:
How do you unlock the password for dell laptop
Related Video:
Windows 7 Forgotten Admin Password Reset
https://www.youtube.com/watch?v=I5HzG7fb-Wg
