Itook cutting deck off gave it a good clean put all back on done a few rows worked perfect the next day went to finish the job and it wont go forwards or backwards and when i put the cutting deck down it seems to have smoke coming out like the belt is slipping? Checked it out seems fine. Only recently gave it a service with all new belts ect. Someone please help??????????
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
SOURCE: hand break on the John Deere LTR 180 is stuck and
To temporarily fix you need to remove brake linkage to trans.If this works you need to get it to the dealer to replace park brake rod.
