Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
marius daugvila Posted on Feb 04, 2012
How to fix a shaking washer bosch 100 - Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
tommy
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Feb 04, 2012
tommy
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
Helped
2308
Points
43
There is no special ballancing act that they do.... there is only heavy springs that try to keep up holding it straight. maybe one is wore out or you just simply overloaded it
Bosch nexxt 100 washer keeps getting water in drum
Check the way the waste pipe is connected to sink drain,could be purge back from here or could be faulty/ leaky fill valve,
How do I replace the motor control board on my own & where is the best place to purchase this part?
try eSpares. Bosch parts are expensive but alternatives are usually available. They also have video tutorials for fixing common problems. Bosch website usualy has diagrams in the spares section. Are you 100% sure it is the control board? It could be something else causing the control board to freeze. For example I recently had to replace the drain pump on our machine.
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
4helpful
2answers
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
5helpful
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
1helpful
2answers
Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
1helpful
Bosch Nexxt series washer - water in softener dispenser
Hi. Remove dispenser, and thouroughly clean.
This should solve problem. If problem persists, don't worry about it tomuch, as long as it takes the conditioner down that is the main thing.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
