Question about Braun Paxiscope XL Opaque Projector - 100522 Projector Lamp
How to replace the Halogen lamp? - Braun Paxiscope XL Opaque Projector - 100522 Projector Lamp
Instruction manual KuKoocooker hood light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
Sep 22, 2014 | Kitchen Ranges
My microwave keeps blowing the halogen lamp
thing to remember about all halogen lamps they are very perceptable to dammage done by forign contaminats on bulb ( finger prints are one of these ) causes hot spots to glass and weakens them allways use a clean soft dry cloth to handle them
Sep 09, 2014 | Microwave Ovens
Installing d2r sylvania lamp in 2001 acura
look in owners manual back index for bulb replacement, it will show and tell you how to replace light bulbs.make sure you wear clean glove when handling halogen head light bulbs because oils from skin will cause halogen bulbs to over heat and blow out, halogen bulbs not cheap.
Jan 03, 2012 | Cars & Trucks
How to change a front turn light in a 1996 taurus.
Lamps, Parking Front Lamp-Lamp Assembly, Taurus
Removal and Installation
  1. Remove Headlamp (13008) as outlined.
Headlamp Assembly
  1. ani_caut.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    Position headlamp switch (11654) and headlamp time delay switch (13736) in the OFF position.
  1. Remove two bolts retaining headlamp (13008) to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle.
  1. Remove park lamp bulb and socket (Sable only) and headlamp bulb and socket from Headlamp Assembly as outlined.
    Headlamp Assembly (Taurus Shown, Sable Similar)
  1. Turn lamp socket and wiring (13410) assembly 1/2 turn counterclockwise and remove from parking lamp (13200) housing.
  1. Remove screw from park/turn signal housing.
  1. Using 1/4 inch drive socket extension and swivel, insert tool through two access holes in upper radiator support. Remove screws from park/turn signal housing.
  1. Remove parking lamp from vehicle.
  1. To install, reverse Removal procedure.
Nov 19, 2010 | Ford Taurus Cars & Trucks
How do you replace the light bulbs? There is a lens cover over the bulb.
This is how to replace the lights on the KitchenAid khlu162m hood. If this is not you hood please give the right make and model # so I can get you the right info.
Replacing the Halogen
lamps:
The hood liner uses 12-volt, 20
watt halogen lamp bulbs.
Before you begin, make sure that
the range hood is turned off and
that the lamps have had sufficient
time to cool.
To replace a halogen lamp:
• Remove 2 screws from the
circular metal trim around the
lamp assembly.
• Pull the trim with the lamp
assembly attached down far
enough so that the lamp can be
pushed out of the socket clips.
• Insert the new lamp into the
socket clips and push the lamp
and trim assembly back up into
the hood.
• Replace the screws.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 13, 2010 | KitchenAid KHLU162M Kitchen Hood
Drum heater lamps
All you really have to do is go to any store that sells halogen lamps and purchase 2,, 150 watt halogen bulbs. That is what the drum heaters are.
I can send you instructions on how to replace them.
rak458@aol.com
I would suggest, if you can find them. Sylvania halogens rated for 130 volts with vibration protection.
If you cant, thats fine, they just seem to not fail.
But any 150 watt halogen will work.
Mar 09, 2010 | Xerox Phaser 8400 Laser Printer
WHAT IS THE BULB NUMBER FOR THE BRAKE LIGHT ON 2005 TRAILBLAZER
2005 CHEVROLET Trailblazer
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
3757ALL
Front turn signal
3757ALL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
Assembly
Fog/Driving light
880
880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3157LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
194
Map light
194
Dome light
212-2
Step/Courtesy light
194
Trunk/Cargo area
212-2
Nov 19, 2009 | 2005 Chevrolet TrailBlazer
Replacement Mitsubishi lamp busted again in less a year!
A Halogen lamp is a Halogen lamp. They are designed to last between 3000 to 5000 hrs.
You got a much longer life than expected on
the original lamp.
Jul 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Braun Paxiscope XL Opaque Projector -  100522 Projector Lamp Logo
152 people viewed this question
Top Braun Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
