I was trying to set the IP address,Subnet Mask and Gateway address manually on the printer itself after connecting it to the router using a network cable. So when i was not able to set it because i didn't know where to locate the space button on the printer, then i tried to use the normal USB connection that i have been using before but it won't print and the print job sent was not even showing on the printer status. Please help me out.
SOURCE: Canon MF4370dn printer network connection problem
I had the same problem. I entered the info manually and it works.
You could follow the instructions on how to do it manually in the e-manual (on the CD).
To get the IP, subnet mask, and default gateway: open a command prompt from windows. At the command prompt, type "ipconfig" without the quotes. Write down the IP address, subnet mask, and default gateway.
For the IP, for example, if what you have from the step above is 192.168.0.100, add 10 (so that you wont have repeated IPs by auto DHCP from the router. I am assuming you have no more than 5 machines on your network.) to the last number to have 192.168.0.110 to enter manually into the printer. Use the same subnet mask and default gateway.
Hope it helps.
Linh.
SOURCE: Canon IR3300 would not scan when use the
give the same class ip address to your printe and computer and install ms office soft ware, and then microsoft tools click that we find the microsoft document scanning create shortcut to the desktop.
ping the printer for computer
run the network scan gear and click on the ip, enter the ip address in the blocks and then the discover.
then scan the document for the ir 3300 scanner.
SOURCE: set up wireless connection canon mp620
I realize that you posted this question over a month ago...but I'll still give you your answer in case anyone else is also experiencing this.
All you need to do is enter in the correct password...the one you gave your router. Which I realize was probably a while back, and you didn't write it down (tisk tisk), so here's how you find out what you typed, way back when.
open up your internet browser (Internet Explorer, Firefox, Safari, ect...). Now in the search bar type in your routers IP address.
mine is: 192.168.2.1
yours might be the same or might be something similar...like: 192.168.1.1
only type that, and include the dots...no www junk.
once you typed it in, hit enter.
and now you should be in your router...then steps hold true for all routers I believe (mines a belkin).
it will ask for a password, most people simply leave theirs the default password, my password was nothing....literally, I just left it blank and clicked 'next'. yours might be 'admin'...a google search should help you find your routers default password.
Ounce you have the routers password, you have access to change a lot of the routers features...including finding out that pesky passphrase that your in search of.
your welcome.
I accept cash & credit. I'll send you the bill. ;)
