Dishwashers Logo
Neil Davis Posted on Feb 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Showing error code E4
Stating that problem is overfill and dishwasher will not work
Andrew Portelli
Level 2:
  • Expert 298 Answers
  • Posted on Feb 01, 2012
Andrew Portelli
Expert
Level 2:
Answers
298
Questions
0
Helped
90501
Points
759
Check for waterleaks filling the overflow tray at the bottom of dish washer that is activating the float switch. check for defects or damage at bottom of dishwasher.
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Nov 07, 2008
SOURCE: dishwasher is flashing error code
"E4" code relates to the overflow detector There appears to be an internal sump. Lean the machine back about 35-45 degrees to remove the excess water from the dishwasher. It might be messy so be prepared. By design the sump collects water from condensation i.e. (Cold outside machine wall, hot inside machine wall) hence condensation builds up and is suppose to and should evaporate in the right environment. Placement and installation locations play into a big part of the design.
You will notice by observation just in the centre there is a polystyrene float. This is what activates the overflow switch which throws the error code.
This probelm is simple to fix, just take off your kitchen plinth and turn off the dish washer power. then at the base of the dishwasher there are 2 plastic clip access panels, take a blunt screw driver or knive to help you ease out the plastic panel. once this is off, simple take a dish cloth out mop out the water, particularly from the left hand side as this is where the sensor is. Once dry (ish) replace the panels and switch on - DONE! its that easy
A
Anonymous
  • Posted on Dec 22, 2007
SOURCE: E4 error on new conia dishwasher
Had the same problem. First you will need to tilt dishwasher back 45 degrees and tip out all excess water. A couple of towels on the floor are a good idea.
Second check that the little nozzle on the elbow under your sink where your overflow attaches is drilled out.
This fixed my problem after fussing around for a day and I was starting to disconnect everything to take it back.
Anonymous
  • Posted on Feb 21, 2009
SOURCE: powerpoint dishwasher E4 error code
The solution below applies to a Powerpoint dishwasher but is probably a generic one for E4 problems - given that brandnames are frequently badges of convenience for made-in-china products.
The problems cause and solution goes as follows:
Problem:
Any water that leaks (for whatever reason) from the internals of the machine finds it's way down to the lowest point of the machine - down under the washzone and into the area where all the workings of the machine are located. There's a sensor there (a polystyrene float operated switch in fact) that detects this water - causing the machine to empty and go into error 4 (E4).
The solution will depend on the nature of the leak. If it's due to one of the various seals on the floor of the washer leaking or there is some problem with water level controls then that will have to be repaired first - otherwise you'll keep on getting the error. In my case however, the "leak" was actually a design feature of the machine and is easily rectified.
Open the dishwasher door fully and look at the floor of the machine where it meets the bottom of the door. You'll see a couple of plastic tubes protruding from the floor by about 12mm - one to the left and one to the right. Their function appears to be to act as an overflow if the water level in the machine gets too high (for whatever reason). This excess water is directed down these tubes and into the bottom of the machine where it can be detected - rather than letting it spill out onto your expensive floor. The weakness in this system is that it only takes a soup spoon of water to produce the error - something which might accidently happen during the course of a normal wash.
Options:
1) Leave the machine idle for a few days until the water evaporates. The sensor switch will reset and the error will be gone when you switch on.
For either of the following solutions, turn off the power to the machine by unplugging it or tripping the relevant switch at your fuse board
The stainless steel washcabinet is only slightly thicker than aluminium kitchen foil. Handle the machine gently and never force it otherwise you're in danger of distorting the cabinet.
2) Tilt the machine right the way forward so that the water leaves the area of the sensor. It'll flow back again once you level the machine but in wetting the floor area of the machine, the level at the sensor will be a little lower than before - permitting the sensor to reset. Switch on and the problem should be gone.
3) Pull the machine out from the built in unit to gain access to the right hand panel. Remove it (just a lot of philips screws holding it on) and you can just about see the polystyrene float (near the front) and the slightly depressed area underneath it - in which the water accumulates. You can poke a stick in with some tissue taped to it to mop up the water. Be careful not to disturb or damage the float.
note:
I've had this problem occur twice in as many years. If it keeps on occurring then you likely have a genuine problem with water level controls during filling or a leaking internal seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
Anonymous
  • Posted on Jun 18, 2009
SOURCE: new world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
paultech8226
  • 109 Answers
  • Posted on Aug 14, 2009
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 • Dishwashers
My Bush dishwasher wqp8-9269 is showing E1. Please help
My bush dishwasher is showing the error code E4 which is an influx overload. I have removed all the water and had the power off for 12 hrs and the error code is still present. What do I do to get the machine to work again.?
Sep 07, 2011 • Dishwashers
1helpful
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
E4 fault code
Hi, when a dishwasher goes into overfill mode it usually means that the bottom tray has water in it that operates a float connected to a microswitch. Open the bottom panel and soak up all water then check to make sure the float is down completely.then restart dishwasher. Why it has overfilled is another problem. It could be a faulty pressure switch,pressure switch hose may have a hole in it, water valve may be faulty. Too much soap or wrong soap can cause too many suds and hence overfill.Also if rinse aid is spilt when filling. Or seals leaking. etc.
Feb 02, 2009 • Dishwashers
4helpful
New world wd60
1helpful
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
35helpful
4answers
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 • Dishwashers
15helpful
2answers
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
3answers
Sep 15, 2007 • Dishwashers
Top Bush Dishwashers Experts
vince
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Bush Dishwasher Expert? Answer questions, earn points and help others
