SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
SOURCE: Remote control programming- Directv
if you have gone through all of the programming codes; you will just have to use the remote that came with the TV set. there is no way to program more codes into the remote, due to its list of codes it was made with can not be updated. i hope this helps
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
SOURCE: tv code
I have an Acer 3720A and Shaw's Atlas PVR remote. I used the "scan feature" to find that code "0704" worked for me (at least for power and volume - which are all I need).
Whether or not this works for you depends on the specific Acer TV you have and possibly the model of "shaw" remote. Many Shaw remotes actually come from Universal Electronics (www.urcsupport.com) and they do not have Acer TV's in their DB. Acer's own site indicates they cannot provide a specific code (at least for my model of TV) and to try the remote's scan feature - which is how I ended up with my solution.
Hope this helps.
