Whirlpool dishwasher model#: (DU1050XTPB3).
my dishwasher seems to be locked up and needs to be reset. the clean led is constantly flashing. i had this trouble in the past, and the serviceman reset the dishwasher by using the touchpad on the front as a code and washer worked again. do you know the code.
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
thanks it works my dishwasher was flashing clean i took it apart cleaned it than put it back together then reset it work better then ever thank you
the reset worked with ours :)
Reset worked, but this is the second time I have had to do it. Any ody know what is causing the lockup?
THANK YOU THANK YOU THANK YOU!!! Was ready to call a service person and/or buy a new dishwasher...but this worked perfectly! All seems to be working fine...now!
Mine dishwasher doesn't have a heat dry and normal button. Normal button includes each cycle (1-hr, light load, etc) and heat dry button includes sani rinse and lock. How do I reset it?
Whirlpool Dishwasher GU2400XTP B1 problem... starts & runs fine until it reaches the HEAT DRY cycle. Then it shuts off, clean LED is flashing.. I've tried the reset code (HD<N<HD<N) it will reset the dishwasher & goes into the rinse cycle again. Unit will NOT get dishes clean NOR will it dry them.. any suggestions ???
Don't ever buy a whirlpool (or Maytag) product ever again. That is the easiest way to not have that problem again. I talked directly to an administrative assistant at corporate and she said that dishwashers and washing machines only last about 5 years from the maytag dependability people. Our old maytag lasted 13 years with one pump replacement. Our current 6 year old just got its third pump replacement. Our old maytag washing machine lasted 19 years. Our current 7 year old maytag washer has had the tranny replaced and the timer switch replaced. I can only say, based on my experience with whirlpool brands; they have implemented planned obsolescence across the brands they sell. I will never buy whirlpool again!
If you pull your dishwasher apart first take out silverware holder then bottom holder then top but the top you have to take out two clips at the end of the track then it slides out next the water jacket on the back its two phillips screws then twist off the spinnner at the bottom of dishwasher thenthere is 4 torx screws pull up then you see one more torx pull off cover an that should be your problem you need to clean that out i clean mine every two months my thinks its a garbage diposal
my whirlpool dishwasher is in lock mode, on the front of the dishwasher is a symbol of a lock with a light above it witch is on. the machine opens up, just will do nothing
