I have a KDL52W5100 sony tv. When I turn it on there are vertical color lines on the screen. If I leave it on for about a half hour then turn it off and back on again it comes back on normally
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
SOURCE: my lcd tv is cracked
If you mind the lines and if they are too big replacing the screen will be very expensive and there is no way to repair your current display. The way I see it if you pay more 65% of the current value of your TV is too much. You may be able to find a new TV for as much as the repair cost.
SOURCE: Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
SOURCE: I have sparkled vertical lines of color on my Sony
You probably have a Bad LCD panel or a LCD controller. Either way, you must replace the LCD Panel because they come as one piece.
Hope this helps,
Skyassoc
