Samsung SCX-4521F All-In-One Laser Printer
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
SOURCE: SCX 4521F scanner driver will not configure. Have
The problem is the firewall of your computer because its blocking the scanner to work better. Check the firewall of your computer from it is control panel if its on. If it is on, click the exception tab then check the network scanner tool and scan to pc box. Just put acheck on all scan or scanner word.
SOURCE: problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: how to download samsung SCX 4x 16 series scanner
goto www.samsung.com and use the search box at the top right and type in the exact model, the x to substitute for numbers/letters isnt helpful so type the exact model in there and it should have a page to download the drivers
SOURCE: I want to download driver for my Samsung
Good day Sir, You can download your Samsung scx-4521f driver in the link below.
Printer Driver
Have a nice day.
