Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca HD52W140 Scenium TV
I have no picture and sound momentarily after i turn the system on. i have no picture and few seconds of sound when the dvd player is on. i have read a few of the responses to a similar problem, i but i do not have the burnt component or part smell.
i would love to know the parts i may need to correct this problem.
  • Anonymous Oct 23, 2008
    No sound
6ya staff
SOURCE:
Bill Heronemus
  • 308 Answers
SOURCE: RCA D52W15 52 in. Rear Projection HDTV-Ready Television
The component connections are usually video only and the audio goes to separate connectors set aside for that input. Check your manual to make sure you have all the connections made.
Posted on Dec 31, 2007
George Kopp
  • 87 Answers
SOURCE: RCA Scenium HDLP50W151
Color wheel bad #212184
Approx $400 by an authorized RCA shop
Posted on Jan 03, 2008
Anonymous
  • 208 Answers
SOURCE: RCA Scenium HD52W140
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
Posted on Feb 24, 2008
Anonymous
  • 61 Answers
SOURCE: RCA P52754AT 52 in. No Picture No Sound
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Posted on Mar 07, 2008
Dave Winterburn
  • 112 Answers
SOURCE: rca hd52w140 tv smelt like burnt plastic and wont come on
Sounds like you have a leaky cap. You might want to replce it before you blow a board and then it costs more money to replace.
Posted on Mar 07, 2009
Hd56w58yx1 no picture, sound for only a few seconds
There are capacitors on the power supply board that dry out with age. You can identify them by observing the tops of each of them. They have to be flat, not domed. Some of them may be discolored from heat. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 12, 2017 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
No picture and loud screeching on RCA Scenium 50" DLP
It sounds like it is the Color Wheel. I do not think you can get the Color Wheel separate from the Optical Engine like you can with Samsung. RCA is very tight with there parts like that. Because you have to get the whole
Engine Assy, cost would be too much in my opinion to invest into it. The part cost approx 800.00 the last time I checked on one.
Good Luck,
I Hope this helped,
Skyassoc
Jun 20, 2009 | RCA Scenium HD65W20 65" Rear Projection...
RCA Scenium 51"- strangest '*******-hissing' sound!!!! Not always
Take out the sweep board ( the one on the left from the back ). Disconnect eleven leads and flip the board over. Look for a bad solder connection on the left... if it's there it will be pretty obvious.
Apr 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium
Sounds like a cold solder joint in the power supply or faulty capacitors.
Mar 11, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Feb 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dec 31, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA model# D61W136D scenium
Sounds like the high voltage transformer is bad. Best bet is to call a service shop. I wouldn't keep watching the set, as this will just cause more damage.
Sep 03, 2007 | RCA D61W136D 61 in. TV/DVD Combo
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
