SOURCE: Selecttech 1090 Dumbbells: the end caps that adjust the weight are stfrozen, ...
Just call Bowflex. If you don't want to call here's the solution. There is a reset button on the bottom of the handle. Take the handle out, place on the floor side ways, depress the square button and turn to 5 lbs. Whatever weights that were on handle will fall out. Place the weights back into the holder. Make sure they are positioned correctly then put the handle back. Then test by dialing up different weight settings and lifting the ******** out of the holder. You should be back in business. If that doesn't work call Bowflex which you should do anyway.
