Toolbox4.9 says supported scanner not installed. Put in disk for printer/scanner and run it, says it has been installed successfully. It shows up with (error) in the Control Panel under Printers, but does not show up under Imaging Devices in the Device Manager. Have tried disconnecting USP, reset, unplugging, and restarting the PC. Scanner and printer worked only moments earlier. Tech suggested a corrupted file. How do you uncorrupt it?
SOURCE: Driver not working
Just as a try- set up a new printer like this Start/printers and faxes/install new printer When you get insert CD or select from list Take Select from list. select then Canon in the makes list and then the model from the model list. Click install See what you get. It is possible you will get the printer only and no scanner - I do'nt know, But try it.
SOURCE: I have installed a Canon MX-700 multifunction
ok
u have reinstall drivers
remove old drivers and install again.
SOURCE: i have purchased this canon
Once you re installed whole software ......... and install one by one softwares frm CD...... and go to control panal and change the settings ther.............
and restart you system .
Hope this will help you out
