I SWITCH THE MACHINE OFF BUT IT WONT START WASHING AND CONTROL PANEL LIGHTS STILL FLIKKERING.
SOURCE: Hoover 550 MA Top Loading Washing Machine
I have 550 Hoover about 6 years old,just out of warranty period,
is currently noticed the problem of stopping during prewash rinse, start again it startsup but stopped immediately.And keep repeating it. If i skip to spin manually then it almost completes the cycle. THis problem starts few months back also then vanished by itself and now it starts again.can some guru tell me if its because of belt or drive belt etc.
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
SOURCE: Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
