Samsung DLP HL-P5663W 56" TV Logo
Cody Chisum Posted on Jan 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
While replacing the lamp on my samsung dlp tv i broke the blue safety switch. is there anything i can do?
Todd Hill
Level 2:
Sergeant:
Champion:
  • Expert 433 Answers
  • Posted on Jan 20, 2012
Todd Hill
Expert
Level 2:
Sergeant:
Champion:
Answers
433
Questions
0
Helped
398934
Points
665
You can just jump the switch
How do you bypass the lamp door cover safety switch on a Samsung DLP tv?
Bare both wires to the switch slightly and twist them together.
2helpful
We replaced the lamp on our Samsung 50" dlp model HL-S5086W tv about 3 weeks ago. Just recently, the tv started turning off by itself and the red standby/temp light and the green lamp light flash for a few...
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • 0helpful
    Samsung tv turns off on its own model hls4266wx
  • 0helpful
    I have had this Samsung DLP HL-P 4663W for about 3 years now.
  • 1helpful
    Samsung 50" DLP still shuts off by itself even after replacing the lamp.
    Make sure the back cover is on properly, there is a switch built in as a safety feature.
    2helpful
    My 56 inch hi-def projection samsung tv turns off automatically
  • 0helpful
    Samsung DLP4663W
  • 0helpful
    TV TURNS OFF AFTER 20-30 MIN
    2helpful
    TV turns off by itselft
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
