Looking for a schematic for a Bosch Dishwasher, model shu43c02uc/14. Appreciate if you have it. Thanks.Looking for a schematic for a Bosch Dishwasher, model shu43c02uc/14. Appreciate if you have it. Thanks.
You can't post conmments that contain an email address.
1.
Take the battery out of the laptop & try to turn on the laptop
using power adapter only. If the computer turns on, then the battery is
defective & needs to be replaced. 2.
Make sure the power adapter is not defective. Test the output voltage
of the power adapter using a voltmeter. Compare the voltmeter reading to
the nominal value written on the adapter or the laptop. 3. Make sure
the DC jack is not loose or broken. A loose DC jack will need to be
re-soldered. A broken one will need to be replaced. 4. If you
have another processor which is compatible with your laptop's model, try
swapping processors & test to see if the laptop will work. 5. The power button could be bad. 6. The motherboard could be defective & needs to be replaced.
