I have 4gb genx usb flash drive and i use it without problem, then suddenly my laptop can not recognized my flash
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a reply
hope this helps you
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
hope this helps you
i have 4gb genx usb flash drive and i use it without problem for many years, the last time i try to open it the on computer which at first recognized my flash but not open then i removed suffly from computer and try again but at that time computer can not recognized flash and i try to open in my laptop but laptop can not recognized it
