I have a philips magnavox projection TV set. The other night the video started to shrink and expand.
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video.
You can find a repair kit herehttp://www.TvRepairKits.com . Hope this helps.
Common problem....Fairly easy fix.
i have the same problem. i heard that you can buy repair kits.
my tv screen shrinks and expands what repair kit do i need to buy?
i need help philipsmagnavox tv set shrink and expand
