No heat from bottom oven, fan and light is working ok. Fitted a new element but still no heat. Any suggestiions?
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
My mum has the same [roblem as this just now and is convinced that it is connected to the timer button which is also not working. she thinks several other people she knows had the same problem but they just replaced their oven rather than repair. Any answers would be gratefully received.
Whilst cooking, whole house fused, and when power put back on, the main oven failed to heat, fan and light are working. I am assuming that the element is broken and it tripped the fuses in my house. Are they easy to replace?
