Digital Blue QX5 Microscope Logo
Posted on Jan 15, 2012
Your microscope is not plugged in, please plug in your microscope (105) or (102)
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 31, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2454
Points
QX3 microscope
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Digital blue qx3 drivers
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Step 1. Download and install the QX3PLUS.EXE software from:
http://tinyurl.com/QX3-Win7-Files
Step 2. Download and install the QCODINSTL.EXE software from:
Step 3. Download and extract the QX3 Drivers from:
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
When i plug in the microscope it says that it is not plugged in yet
file the plugged in area gently then connect it.it may be workouut try it once
I have XP and the qx3 software runs but it won't recognize the microscope
Before you run the program, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Error Message 103
I think it maybe because you haven't installed the "Driver" either at all, or properly. Uninstall any/all software. Reboot, DO NOT plug in unit. now, re-install the Software and Driver. Reboot, NOW plug in the unit, it should now be detected, and work.
You don't say what OS you are using? If Vista or Win 7, try installing as Administrator and also set Compatibility Mode for XP SP2 and run the main .exe as Administrator too.
6helpful
2answers
QX5 Problem with Windows Vista
Do not plug the QX5 in until the software is installed.
I got mine to work on Vista 32bit. Insert the cd, cancel autorun, view files on the cd. locate setup.exe, right-click on the setup and go to properties; then compatibility; then put a check in "run this program in compatibility mode for windows xp" AND put a check mark in "run this program as an administrator; the click Apply and click OK.
Right-click on the setup.exe again, this time choose, Run as Administrator.
Install away from the default. My recommendation is c:\users\(your user name\digitalblue.
Plug in the QX5, then go to Start, Programs, Digital Blue, click on QX5
10helpful
3answers
Qx3 miroscope
This worked for my QX3 on my Vista computer!
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Qx5 microscope is shutting down.
Does this device run from USB power.. (no plug in power supply) if so, the problem may just be that this device (not limited to microscopes) is trying to draw too much power, as not all USB ports are born equal (a common problem in laptops). the solution is to either buy a power supply for the microscope or get a "powered" USB hub (a usb hub with it's own plug top power supply) I hope this helps
2answers
Qx5 is not responding
the microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
Top Digital Blue Science & Laboratory Experts
ADMIN Eric
ADMIN Eric
Allan Kipyego
Allan Kipyego
Level 1 Expert
Collins Mccoy
Collins Mccoy
Are you a Digital Blue Science and Laboratory Expert? Answer questions, earn points and help others
