Samsung WEP170 Wireless Headset Logo
Posted on Sep 24, 2017
It is not good at all, it was a wrong choice
I recently picked up a WEP170 and I'm having troubles with it.
I cannot turn it on at all.
It also does not seem to charge at all.
When I attempt to charge it, the indicator light turns red for a moment and goes directly to blue, indicating that the unit is charged.
When I try to turn it on, nothing happens. No lights, no beeps, no nothing.
Elapatha Kumarasiri
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on Sep 29, 2017
Elapatha Kumarasiri
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
10
Questions
Helped
4262
Points
28
You can change the rechargable battery inside and see what will happen.
1 Related Answer
Anonymous
  • Posted on Aug 08, 2007
SOURCE: Can't Turn on/Charge
I had the same problem when I purchased mine. There was nothing to do except return it for a replacement.
1helpful
My recently made music CD will NOT play in our Philips FW-R7. It will play on all our computers and DVD players. The message is "Wrong Disc." Other music CD we've made do play fine in the FW-R7.
This is common with burned cd's they have trouble playing in different sets. Do prerecorder cd's play fine in your philips? If those are having trouble also you could improve it's playability possibly with a cleaning of the opu. Optical pick up.
1helpful
2answers
Cannot find manual,need passkey for WEP170
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?AT_ID=71243&PROD_ID=786&PG_ID=-1&PROD_SUB_ID=0
The manual can be found here
1helpful
I have a minolta 7135 in my office at work and it show the code F-35-8,what's wrong?
Hello sir; The error code you display, it means fuser temperature too low, but it can be reset;
1, hold down 2 & 5 keys while you turn on power.
2, choice 1 for software switches.
3, use U/D arrow key to pick up dipswitch and bit number.
4, pick up dipswitch 3, bit 1 and change 1 to 0 by pressing "off"
14helpful
2answers
Passcode for Samsung WEP170
must start with headset turned off.
1) turn on headset and keep your finger pressed until the blue light stays on
2) now let your phone search for the device. when it does select it
3) the pin is 0,0,0,0
4) then it should be matched
Turning off indicator light function
Please describe the specifics of your problem below. We'll add
your post as a comment to timf1728's Can't Turn on/Charge problem, and notify you when a new solution is offered.
Soft, rubber like piece cover speaker on Samsung WEP170 Bluetooth
I bought a pair of Sony headphones for my MP3 player, they came with three sets of rubber covers for the bud part of the head phone.
I have the WEP 170 also but didn't like how it fit in my ear, so I took one of the Sony bud cusions and replaced it with the one on the WEP, works great and even helps to cancel out noise.
Hope this helps
RoToHakr
2answers
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Top Samsung Radio Communications Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
