The 2 gray plastic water lines coming out of the top left corner of the back of the refrigerator end in brass metal thread connectors hanging 6" above the floor. The left 1/4" plastic line has 2 blue bands on it. The clear plastic line coming out of the upper right corner of the back ends in a female threaded fitting. This fridge was given to us. The water installation instructions show just one connector to the water supply line of the house. Why the 3 lines all ending in an open fitting.
You need to get the model number... look up the DUAL water valves (which seem to be missing) and hook up the water & ice RESPECTIVELY
Watch those supplier videos...
Those new press connectors are a snap to
use (and release)...
appliancepartspros
Search Over 2 1 Million Appliance Parts
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
kit LIKE THIS... (can't tell w/o model number)
Amazon com 2181730 Quality Replacement Dual Water Valve Kit for...
Carnac the Magnificent
SOURCE: LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
SOURCE: Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
SOURCE: We have a u-line ice
It should be going to the fill valve inside of the unit. it should be by the evaporator plate.
SOURCE: Water line compression fitting not working
there should be a insert that goes into the water line at the end after the compresstion fitting is slid onto the tubing. you call allways take and go to ath eharware store and get a new compresston coupling for this situation.
SOURCE: I have a new Whirlpool refrigerator (model
Order an "Icemaker" install kit with plastic tubing. This will solve your problem.
Bi Coastal Appliance Parts @ 1-800-673-1262
