None of my burners are sparking at all. I have a new ignition control unit that I want to put inside my cooktop. I've removed the burners and have unscrewed the brass rings that feed the gas to the burner. There is still a metal piece on the cooktop which is on top of the round white base that exists for each burner. I can figure out how to get the rest of this stuff off the cooktop - no visible screws or threaded parts (unless one needs a special tool for that). Appreciate any advice!
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
SOURCE: Electric coils for old Thermador cooktop Model #TMH45
i just checked repairclinic.com and they seem to have a lot of parts for Thermador. you just need your model number. if the burners look anything like this, then you might be able to buy aftermarket burners a lot cheaper at lowes or home depot. thermadore parts are very expensive.
SOURCE: Need to convert a Thermador cooktop from Natural to LP
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1048620&PPStack=1
try this link.
do not drill out the jets they will not work properly.
I would check all your documentation you may have the convention kit with your owners manual or it may be attached to the oven.
SOURCE: Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
SOURCE: Looking for new spare parts Creda Gas cooktop 42320
Contact this gentleman: Sandor Horky [email protected]
He helped us with parts we needed for our CREDA Model GGH110. I believe the company ADCO is the after market people for CREDA. Good Luck. PA Fi.
