disassemble clean and assemble paying attention to condition
noise from bearings going out/screeching ???
noise from unbalanced load/ lots of vibration??
noise from scraping/grinding/metal on plastic ??
noise from scraping/grinding/plastic on plastic ??
there any burning smell also ??
is any part getting warm ( turn upside down to check ) ( hold or place on thick layer of kitchen towels
be aware if it is old ~ 20 yrs give or take 20 yrs getting a new juicer will be less hassle than trying to repair
Using a screw driver remove screws to detach the thing that locks the attachments into place. You will see a rubber seal around the socket in which the auger is fitted. Remove the seal and put a little oil on it. Replace everything after doing the lubrication.
There may be an overload switch somewhere on the unit, it will just be a small button projecting from the underside most probably or in a small hole. If there is, just depress it. If the unit actually burned out yu would have seen smoke and smelled it.
1-973-287-5150. VERY SHORT WARRANTY. IF OUT OF WARRANTY GO FOR SOMETHING BETTER. GOOGLE FERNS NUTRITION, THEY SELL JUICERS AND GIVE GOOD ADVICE. I HAVE AN ACME SINCE 1990 AND RUNS LIKE THE DAY I GOT IT. TAKE A LOOK AT THE LEXEN GP62. THE HUROM SLOW JUICER IS GREAT, BUT BIG BUCKS.
Assuming the motor is not totally burned yet, Make sure the blade is fiitted in its place right. Take the blade out again and fit it right along with the strainer. If it is not seated and fitted well, it will touch the upper cover and will not turn and will smell burnt.
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked.
Hello Duane,
Your machine is equipped with a magnetic start system which will only allow
the machine to start when you have the screenholder all the way in place
just as you would have it to start juicing. If you do not have any parts on
the machine it will not start. Please assemble it again and give it a try.
If it still wont start call me at 209-369-2154 for further assistance.
Thank you
Carl
