The right wheel on my Pride Jet 3 electric chair won't move, but the left one does. Does one battery drive one wheel and one the other? The light indicates the battery is charged. It has sat in a garage for 7 years, but was working when it was put there. I have engaged and disengaged the free wheel lever a number of times. I have also checked the connections.
SOURCE: Pride JET 3 Ultra power wheelchair. Problem:
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
