SOURCE: How can I turn off the beep sound on my exxcel
I've just found my instruction manual and managed to turn the volume off on mine after 6 months of annoying beeping.
You turn the programme selector to off then turn it one programme to the right, press the rpm button and keep it pressed while turning one more programme to the right, release them both and a number should be displayed on screen I think volume 2 is the default one. You then click the "ready in" button until desired volume is reached. You have a chioce of zero through to four. After volume is set turn programme selector to off position. The annoying beep should be no more!! Hope this helps others.
SOURCE: blue stains on laundry
I was talking toa repairmain about which washer/dryer to get and he mentioned that the Bosch can stain clothing blue. I don't know anything else about why...but I'd contact my Bosch dealer.
SOURCE: Cannot remove pump filter cover -Bosch Exxcel 1400
Before removing the filter have you drained the excess water with the drain hose to the left of the filter? The filter cap should turn around 1/4 to 1/2 turn so the best option is to close it again and then repeatedly try opening it with a little more force each time. The black plastic cage could affect the removal of the filter and once removed if it is damaged you may need to replace it. These are available via most domestic appliance spares stores or directly from Bosch. Once removed check for any black plastic debris in the filter housing and chamber.
Testimonial: "Very helpful response - thank you."
