SOURCE: Paul Jardin Chronograph watch
Follow this link and type in your model number on the right side of the page.
http://www.bulova.com/service/instructions.aspx
After typing in find now. Click on the underlined here and you should find your instructions.
SOURCE: setting a Citizen Chronograph watch
assuming the battery isn't dead (IF IT IS DON'T TAKE THE BACK OFF, YOU
WILL LOSE THE SPRING THAT MAKES THE ALARM SOUND) the button on the
bottom right click it until the function selector is pointed to time,
then pull the button out, then the top two buttons i believe change the
hour hands. before setting the time you will need to zero this watch
out, or calibrate it or the date will not change in synch with the time
at midnight.
my battery is dead and i am a truck driver and am therefore having a
difficult time (no pun intended) finding a place i can get parked to
have my battery changed. please believe me when i tell you that you
will lose this spring, a jeweler lost mine once and it took months to
order a new one
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
SOURCE: I need instructions on setting the alarm for the
I answered this for different Fossil watch post, but I believe it will be the same for your watch.
I'll re-post the answer below.
To set the alarm on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
Second, set the correct time. (plus one or two minutes... time to complete this.)
Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
Fourth, push the crown all the way in- to position #0.
The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
To set the alarm SOUND time, pull the crown out to the first click (position #1).
Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
I hope this helps.
SOURCE: I need an instruction guide for a Pulsar N945-6A20
Go to pulsar website look under manuals and select PWF series
