SOURCE: Bosch Classixx 1000 manual
usually it is the larger for the main powder the second largest for the prewash powder and the smallest (labelled with a "max line" for the fab conditioner) the calgon can go in with the main wash or be put straight in the drum.
SOURCE: replacing brushes bosch classixx 1000
Hi ya
The brushes on the machine are located on the motor. The motor for this brand of machine is located on the bottom of the drum. The brushes are in black holders usually but can vary in colour.
The are simply held to the motor with 2 screws each either side.
The best way is to disconnect the pipes from the machine make sures theres no water in the machine and and flip it onto its head i.e. upside down.. use a short handle posi screw drive to remove the brushes from the motor and disconnect the the little wire wire from the end of the brush and remove and replace its that simple
hope that helps
washdoctor
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
