Http://blog.fix4dll.com/fixing-the-mss32-dll-is-missing-error-in-call-of-duty-4/
backup old mss32.dll file first by renaming it in system folder where it lives in hard drive then replace file with the new mss32.dll file
yuotube also has some videos on this
SOURCE: warchest won't play . It says missing file
http://www.dll-files.com/dllindex/dll-files.shtml?mss32
Copy the file into Windows\System32 and reboot. If this doesn't fix it, copy the file into the game's folder.
SOURCE: How do I solve the
Any .dll database/archive site should have MFC30.dll. I personally use http://www.dlldump.com. You'll have to download it, unzip it, and place it into C:\Windows\System32, which should solve your problem.
SOURCE: Still life.exe _ Entry Point Not Found The
it means that the version of windows your trying to install on (eg.windows 7 home premium 64 bit) is not compatable with the game try installing on older mechine (eg.windows 98) it would work fine
SOURCE: fmodex.dll the entry point could not be located in the dynamic link library folder
Method 1:
I would suggest you to uninstall the audio drivers and re-install once again.
To uninstall audio drivers from the device manager follow these steps:
a. Click on Start.
b. Type "Device Manager" in the search bar.
c. Click on Device Manager.
d. Select the device you wish to uninstall in the Device Manager window and uninstall it.
e. You can also uninstall by right clicking on the device and selecting
Uninstall from the context menu. A dialog box will open asking you if you really wish to uninstall the driver. Click
Yes, then OK in the next window.
Install the audio drivers from the manufacturer's website.
Method 2:
Try to re-install the game in cleanboot mode and check if it works.
http://support.microsoft.com/kb/929135
Note: When the troubleshooting is over do not forget to reset the computer to normal startup. Follow the step 7 in the above article.
If the issue still persists, then contact the manufacturer of the game.
Good Luck!
