Ice maker quit working after we emptied the "space saver ice storage caddy" for a camping trip. The power did not go off; nothing froze around the opening. The water in the door works and the ice dispenser in the door sounds like it is working but nothing's coming out because there's no ice in the caddy. Everything else seems fine. Help!
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
[email protected]
SOURCE: ice maker doesn't dispense ice
The most reasonable things could be that the gas ran out; the buttons and thermostat don't work; power issues; or you might have a leakage on the gas pipe.
Try calling a fridge/air condition technician to verify this.
