to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
it probably has developed a loos connection inside. Pressing on that part reconnects the loose connecion inside the machine. If you are someone with a good mechanical aptittude, you may open it and somehow make a hood connection again. The problem should be obvious, and straight forward to fix.
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked.
Hello Duane,
Your machine is equipped with a magnetic start system which will only allow
the machine to start when you have the screenholder all the way in place
just as you would have it to start juicing. If you do not have any parts on
the machine it will not start. Please assemble it again and give it a try.
If it still wont start call me at 209-369-2154 for further assistance.
Thank you
Carl
Hello Duane,
Thank you
Carl
