My chair is making bad noises from underneath.. it sounds like the sound of a jeep or 4wheel drives big tires sound like.. that's the best way i can explain it.. and since last night, when i back up, it will make a sound like i had run over something, like a grinding kinda sound.. it's an old chair but the only thing i have right now to get around it, and if it goes i'm gonna be confined to,?, i don't know.. like i said, it's an old chair, it has jet on the footplate, and on the back it has Pride with a bar code below it.. can you help me to fix the problem?? thank you, David Tallman [email protected]
SOURCE: pride jet3 makes noise when engaging forward motion
Sounds like your motors are gong out. You`ll need to get to a reputable dealer for further diagnosis.
SOURCE: pride power chair jet 7
Have the batteries load tested. Most likely they need to be replaced.
SOURCE: I have a quantum 6000
Jal Check with your provider and ask them for a pair of Elevated Leg rests for your chair. They might have to install the holders for the leg rests but that is an easy job. And they are fairly inexpensive and can be put on and taken off easily. Hope this helps you
SOURCE: I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
SOURCE: my pride go chair controller
How many yellow are flashing constantly? take a look at this link as well is this the type of controller you have and the type of display for the bars http://www.pgdt.com/scenter/diagnostics/diagvsi.html
if you have any further questions message me back and please remember when this chat is concluded to rank how this opinion has helped in your situation Thanks again
Rick
