Location and photo
SOURCE: 1998 chevy suburban map sensor
Hi, The Map sensor on a Suburban is located.
Beside of the ignition coil. on the intake.
Is a litle sensor with a connector of 3 wires.
I hope this work for you. OK
SOURCE: knock sensor for a 2003 chevy Z71 5.3 L
These sensors are quiet a problem. They are located under the intake and normally go off because the engine got washed sometimes the water will evaperate and the problem goes away but anymays the intakes gota come off there are 2 of them so i would recomend replacing both while ur at it
SOURCE: Where is the location of the knock sensor for a 2005 HD 2500 6.0
HAS TWO KNOCK SENSORS they are both under intake in valley of engine. remove intake and will see two black grommets they are under those best to replace both at same time
SOURCE: knock sensor location
HI, click the link below to be directed to a full diagram that will show you the actual location of the sensor. 718 will be the actual sensor to extract and 739 is the mounting screw for the KS.
KNOCK SENSOR DIAGRAM
SOURCE: where are the knock sensors located on a 02 chevy
It is usually below the the cylinder head on the passenger side towards the back of the engine. It has a white single mushroom shaped connector.
