LG 47LC7DF 47 in. LCD HDTV Logo
Posted on Jun 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg 47lc7df tv blinks green light, no picture or sound
When you first tv on and press the power button the indicater light blinks 18 times then stays on solid green. The backlight comes when the light is steady green. There is no picture or anything. Nothing happens when you press any buttons except power button that turns off the tv. There are no blown caps on the power board. I also checked all voltages coming out of the power supply and they are within specs. So wondering what else it could be?
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Jun 27, 2017
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14990307
Points
237762
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
5 Related Answers
Anonymous
  • 187 Answers
  • Posted on May 27, 2009
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Anonymous
  • 12 Answers
  • Posted on Jul 14, 2009
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Chris Sorrows
  • 136 Answers
  • Posted on Aug 08, 2009
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Anonymous
  • 5 Answers
  • Posted on Aug 31, 2009
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
Anonymous
  • 644 Answers
  • Posted on Feb 01, 2010
SOURCE: 47LC7DF, Green light comes on, blinks with remote
When you say that you have replaced the main board i assume you mean the power board? If the green light comes on and blinks when the remote is touched it was never a issue with the mainboard, if it was you wouldnt have any signs of power. In most lcd tvs you have the main board which is normally the power board, the signal board which recieves signal and hold settings of the tv which can be all in one, the other is the inverter board, which scrambles the signal to what you see on the screen, and next we have the back light which lights the screen so you can see the picture, sometimes in certain models as i have learned you can have power/inverter boards which means the inverter and power are all on the same board, in your case i pressume the inverter board is seperate board and probably the issue you need to address, you can buy these online probably the same place you got your new mainboard from. Hope this helps pls post bach what happens.
I have an LG 47LC7DF and I only get a red light when the power is off and when I turn the power on, the green light flashes a few times and then stays on. I do not have a picture or sound. Please advise...
Red light means your tv is in the stand-by mode..There could be serveral problems? Like your Y main board,T con,Upper & Lower buffer..Need to have a professional take a look ...
1helpful
Have a LG 47LC7DF tv and its starting to have a hard time turning on. Green light flashes for 15 secs and screen lights up a little with no picture or sound. Have to unplug it to shut it off sometimes....
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this work out in solving the problem.....
My lg tv when i turn it on the picture blinks three times n then turns off
If the set goes dead after 3 times then suspect power supply, if a light stays on then main logic board.
Lg tv no sound or picture, blinking green light but back light on
The common problem is the main board, instead to purchase a expensive main board, you may try to re-flow the soldering on the main board, it is the only way you may fix the main board at your home.
Re-Flow Soldering Procedure for LG Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
6helpful
2answers
Well dont keep it on!
By running it after it shutdown and it finally did its last pop that added another $XX to the parts bill.
The control boards (2) have now failed There are burned Capacitors ( pop!) and possibly even a few transistors burned out. This is not a DIY it is a Tech job as once changed these boards require additional tuning of the convergence factor.
No picture no sound
seems to be common faults with this model in LG there have been a number of their models recalled to fix power board and the video controllers
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
